System Setting for Default Font
mrichard5689
Apologies if this is posted elsewhere, I just can't seem to find an answer.
All of our email notifications are in Times New Roman by default. I would like to change this to Calibri, to match with our internal corporate communications. Does anyone know where the system setting is to change all outbound communications to a particular font and font size?
13 REPLIES 13
chr_kluge
Hi Karl
This did the trick.
Except of the visible Ref watermark, which is still in Times New RomanwatermarkTNR.JPG
Hi Christina,
Quick question. I know this is an old post, but who knows!
Have you found a solution to align the watermark font to the rest of the email?
Thanks in advance, and have a good day.
Hi Julien,
You could add a business rule on the email table which checks for new records which contain a watermark, detect it and next wrap it in a DIV-tag which will include your styles.
Other option would be to make the watermark invisible using the property "glide.email.watermark.visible"
See also here: http://wiki.servicenow.com/index.php?title=Email_Properties#Outbound_Mail_Configuration
Hope that Helps,
A.
julienr
Mega Contributor
Thanks A.,
As we have to keep the watermark visible, I'll try the business rule option
Have a good day
