Unable to access Multi Row Variable Set values in Flow Designer – Grayed out in Create Catalog Task
Hi Team,
I have a Catalog Item where I am creating a Catalog Task (sc_task) using Flow Designer.
For normal catalog variables, I am able to populate the values in the Description field of the Catalog Task using:
Trigger → Requested Item → Variables
However, I have a Multi Row Variable Set (MRVS) on the catalog item.
When I try to access those variables inside the Create Catalog Task → Description field, the MRVS variables are grayed out and not selectable in the data pill picker.
Requirement:
After the catalog item is submitted, I need to display a variable value from MRVS in the Description of Catalog task.
14 REPLIES 14
Thanks! I’m also sharing a blog I wrote on this topic — “How to Safely Calculate Percentages in a Finance Flow Designer Using MVRs and Set Cost Centers”.
It demonstrates the same approach with inline scripts (f(x)), looping through MVRs, and safely handling percentage calculations. I hope it will be helpful for others working on Finance flows 👍🙂
Re: How to Safely Calculate Percentages in a Finan... - ServiceNow Community
@Community Alums
I shared the above approach which satisfies your requirement.
Please check and let me know the feedback.
@Community Alums
Hope you are doing good.
yashkamde
Hello @Community Alums ,
First of all you will need to extract the MRVS values, so you can use this approach :
1) Create a custom action and pass your mrvs variable from Get Catalog Variables step taking input as json:
2) Inside the Action use script step so their you can send your values as output to display a variable value from MRVS in the Description of Catalog task :
Multi Row Varaible set will retrun in Array of Object, so use for each loop and iterate then you can read the elements in it
