Urgent: Need help- UI Macro should run based on Roles.
Yogesh14
Hello, @Ankur Bawiskar
I have created a UI Macro: to add new options to a field and it is working fine for me. But when i am impersonating to other user with ITIL role it is not working.
If we add any value in Add Data field and click on Primary Button and save the form then the value will be added and we can see that value in New Values dropdown.
UI Macro script:
	<a onclick='updateList()'>
	<span
            aria-label="${HTML:gs.getMessage('Update List Field Choices')}"
            title="${gs.getMessage('Update List Field Choices')}"
            alt="${gs.getMessage('Update List Field Choices')}"
		<button type="button" class="btn btn-primary">Primary</button>
		</span>
	</a>
 <script>
	 function updateList(){
	   var listfield = 'u_new_values';//replace with the name of your List field
	   var tablename = 'u_new_table';//replace with the name of the table you created the List field on
	   var choicetext = g_form.getValue('u_add_data');//replace with the name of your String field
	   var choiceGR = new GlideRecord('sys_choice');
	   //first check to make sure the choice doesn't already exist
	   choiceGR.addQuery('name', tablename);
	   choiceGR.addQuery('element', listfield);
	   choiceGR.addQuery('value', choicetext);
	   choiceGR.query();
	   if(choiceGR.next()){
	     alert('Choice already exists on List');
       else{
	     //choice not found so create a new one
	     choiceGR.initialize();
	     choiceGR.name = tablename;
	     choiceGR.element = listfield;
	     choiceGR.language = 'en';
	     choiceGR.label = choicetext;
	     choiceGR.value = choicetext;
	     choiceGR.insert();
	     alert('Choice added to List');
	     g_form.clearValue('u_add_data');//replace with the name of your String field
  </script>
</j:jelly>
Yogesh
this line is not present in your UI macro
<j:if test="${gs.hasRole('itil')}">
It seems the itil user is not able to insert new choices using GlideRecord
Can you check what comes in alert for bold
        <span
        </span>
    </a>
    <script>
        choiceGR.query();
        else{
        alert(choiceGr.canCreate());
        alert(choiceGr.canWrite())
        choiceGR.insert();
    </script>
</j:jelly>
Hi Ankur,
after adding these 2 lines nothing is happening. I mean no alerts and the data is also not getting inserted.
alert(choiceGr.canWrite());
Yogesh
not very sure then
regards
