using flow designer I want to trigger assign to
armanoj
in custom table with list field group refer to group table.
i want create some custom task using sheduled job.
scheduled job run  every 6 months.
department field contain multiple values
eg: Group1,group2,group3.
newly created task assign to needs to be corresponding department (group) manager.
example:
1 . record have 2 groups.
then task needs to create for to managers while runing the job.
15 REPLIES 15
Hello @armanoj ,
I'm glad your query is resolved 😄. If my response helps you you can accept as solution. So it will helps further future queries.
