Using Glide Query in transform map script to retrieve values and update in target record
Geeta5
Giga Contributor
I have requirement where in transform map script(here Source table: staging table and target table : cmdb_ci) I have to check certain values(application_owner, application name)  from sc_req_item table based on a match of 'alert id' and get values from sc_req_item table and update in target table(cmdb_ci).
I have written below code in Transform map script but I am not able to fetch values from sc_req_item table.The if loop (line  19) is getting executed i.e condition evaluates true, but I am not able to get value of 'Application_owner' , 'application_name'(line 20,21 not returning value). Please suggest how to achieve this.
MrMuhammad
Hi @Geeta,
if application_owner and application_name are variables on sc_req_item table then update below lines as.
application_owner = gr_req.variables.application_owner;
application_name= gr_req.variables.application_name;
Thanks & Regards,
Sharjeel
14 REPLIES 14
Try with logs.
gs.log(gr_req.variable_pool.application_owner);
gs.log(gr_req.variable_pool.application_name);
if(gr_req.next()){
application_owner = gr_req.variable_pool.application_owner;
application_name= gr_req.variable_pool.application_name;
target.application_owner= application_owner;
target.u_application_name = application_name;
MrMuhammad
Hi @Geeta,
Thanks & Regards,
Sharjeel
Thanks Muhammad, it worked.
Happy to help. Have a great weekend 🙂
Please select appropriate response as correct as it is reference for others with the similar problem in the future.
