Using Problem Management for only resolved incidents
LuanneI
We only consider problem investigations on resolved incidents currently. Anyone using problem to identify root cause and implement fix for active incidents. Can you share your workflow?
Dr Atul - LNG
You need to change the field reference “Quality” to allow adding any incident. This can be easily done using the dictionary override if required.
