Using replace in run script is not working
phoang
Kilo Expert
I'm trying to replace spaces in my string with a comma within a Run Script in my workflow, but I keep getting 'undefined'.  This is what I've tried:
var copyNona3 = copyNona.replace(/,\s*$/, "");
var copyNona3 = copyNona.replace(/\s/g, ',');
But none of that worked.  I also joined a split().join() but that didn't work either.
Can you use replace in a Run Script of a workflow?
Thanks.
Phuong
asifnoor
If you are getting undefined while calling replace, then copyNona might not be a string. Convert to string and then check it.
If you are getting undefined while printing copyNona3, thjen try this code
var copyNona2 = "Testing";
var copyNona3 = copyNona2.replace(/\s/g, ',');
Mark the comment as a correct answer and helpful if it helps.
got it - need to put in string first...thanks!
asifnoor
Aaaah yes that was it.  Thank you!
