we do integration using flow between two tables in the same instance
06-04-2024 11:50 PM
If I create a ticket in incident table that ticket should come to my custom table. Just like we do integrations between two instances , can we do integration using flow between two tables in the same instance ? Is this possible?
06-05-2024 01:50 PM
Hi, I am curious as the use case\business driver that requires duplication of your Incident record, as this type of behavior is not known for efficient or consistent results.
If you are simply creating (or syncing) records across 2 tables, then I would think the best practice solution would be by using 'after' business rules.
06-13-2024 06:03 AM
Why? What is your use case?
