09-29-2025 11:28 PM
What is the difference between Insert, Insert and Stay, and Update in forms?
09-29-2025 11:30 PM
Hi
I hope my answer will resolve your issue
Insert → Save record and go back to list.
Insert and Stay → Save record but stay on the form.
Update → Save changes to an existing re
09-29-2025 11:45 PM
Hi @kishorchika
Insert
Creates a new record in the database.
After saving, the system returns you to the list view (not the record you just created).
Used when you want to quickly add a new record and then move back to the list.
Insert and Stay
Also creates a new record in the database.
After saving, it keeps you on the same record form.
Useful if you want to continue working on the newly created record (e.g., add more details or related information).
Update
Saves changes to an existing record.
No new record is created - it simply updates the current record.
After saving, the system usually takes you back to the list view (though behavior can depend on configuration).
