‎08-11-2020 11:48 PM
I'm working on a record producer used in our Service Portal.
onSubmit the Ticket form summary holds information from filled out variables - but not the variables in my multi-row variable set.
I've checked that the setting 'Visible on summaries' are set on all variables in the variable set.
What do I do wrong??
Kind regards,
Janne
‎08-11-2020 11:52 PM
Hi Janne,
check this link talks that it is not possible and might come in later release
Multi Row Variable Set data is not displayed in the Ticket Fields widget
please check below link; it talks about MRVS issues
Issues that you did not know about a multi-row variable set
‎08-24-2020 03:16 AM
Hi
I see you try marking multiple answers as Correct. Only one can be Correct. Can you mark the best one as Correct and others as Helpful?
Kind regards,
Willem
‎08-25-2020 03:10 AM
Hi Willem.
I think i'ts difficult to answer, which reply is correct - I got the needed information from both replies.
Kind regards
Janne.
‎08-25-2020 03:14 AM
