3 weeks ago
How can I prevent certain users (based on their roles) from accessing the employee center?
I can redirect to /sp or the SOW easily enough, but that doesn't prevent the user from simply changing the url to /esc. I want to prevent them from accessing /esc unless they have a certain role.
3 weeks ago
let them go to ESC portal, you can add a widget on that homepage or use UI script and check what role they have
if they don't satisfy then take them to SOW or SP or wherever you want
1) Approach 1: Widget
How to strictly restrict Portal access by Role?
2) Approach 2: UI Script
Another method is to use UI script, see below link for approach
Solution: Redirecting Users to the CSM Portal Based on Roles in ServiceNow
3 weeks ago - last edited 3 weeks ago
Here's the final solution details. My 'true/false' answer may seem backwards but it works. Anyone who meets certain criteria in the Script Include who I want to access the ESC I return 'false.' Anytime they enter any /esc url they are directed back to /sp. (Edited to add the details around redirect at the bottom.)
Script Include:
Name = 'getMyPortal'
Application = 'global'
Accessible from = 'All Application Scopes'
Glide AJAX Enabled = TRUE
Script:
var getMyPortal = Class.create();
getMyPortal.prototype = Object.extendsObject(AbstractAjaxProcessor, {
xPortal: function() {
var hasITIL = gs.getUser().hasRole('itil');
var com = gs.getUser().getCompanyID();
var isMyCompany = false;
if (com == '<company sysID>') {
isMyCompany = true;
// if (hasITIL || isMyCompany) { //check company people or users with ITIL can get to Employee Center
if (isMyCompany) { //only check company can get to /esc
return false;
return true;
});UI Script:
Name = 'getMyPortalUIScript'
UI Type = 'All'
(function() {
var ga = new GlideAjax('getMyPortal');
ga.addParam('sysparm_name', 'xPortal');
ga.getXML(NewParse);
function NewParse(response) {
if (answer == 'true') {
window.location = '/sp';
})();The sp_portal record for /esc is using an sp_theme. The sp_theme has an entry on the 'JS Includes' related list. That entry is:
Display Name = 'getMyPortalUIScript' (not sure if the name actually matters)
Source = UI Script
Application = Employee Center
UI Script = reference to 'getMyPortalUIScript'
From a redirect perspective, so users are automatically redirected from platform to /esc or /sp:
Script Include:
Name = SPEntryRedirector
Application = global
Accessible from = This application scope only
var SPEntryRedirector = Class.create();
SPEntryRedirector.prototype = {
initialize: function() {},
getFirstPageURL: function() {
var userGR = new GlideRecord('sys_user');
if (!userGR.get(gs.getUserID())) return null;
var internalCompanySysId = '<company sysid>'; // company sys_id
var isInternal = (userGR.company && userGR.company.toString() === internalCompanySysId);
var hasItil = gs.hasRole('itil');
// Let ServiceNow handle itil users
if (hasItil)
return null;
// Only route non-itil users
if (isInternal)
return '/esc';
else
return '/sp';
type: 'SPEntryRedirector'
System Property:
Name = glide.entry.first.page.script
Type = string
Value = new SPEntryRedirector().getFirstPageURL();
3 weeks ago
With some customization in OOTB Script Include of SPEntryPage you can take user to particular SP or ESC portal on login.
But if they change URL and manually visit then that won't work.
For that you need to take the approach I shared above.
3 weeks ago
I believe I shared a working approach from that link and you can enhance it further.
3 weeks ago
Thanks @Ankur Bawiskar for the links. I was able to combine option 2 with an old note that referenced this article (Service Portal Domain Separation workaround - ServiceNow Community).
I was able to use the UIScript, Script Include, with a JSInclude on the theme for my ESC. This appears to be preventing any users from accessing the ESC based on whatever conditions I want to set in my script include, and it's still following my existing redirect logic so I don't have to worry about platform view.
Thanks again
3 weeks ago
Glad to know.
Please do share detailed solution so that it helps other members in future.
Script Include:
Script:
isMyCompany = true;
return false;
return true;
});UI Script:
UI Type = 'All'
(function() {
Source = UI Script
Script Include:
if (hasItil)
return null;
if (isInternal)
return '/esc';
else
return '/sp';
System Property:
Type = string
