Users should not be able to close tickets from employee center
Edward Rosario
From my Tickets a user can Resolve an incident (this is OK),  but once resolved they can then Close a resolved incident.
This should not be allowed, closing should only be done by admins or the system.  Where can I edit this to meet the above criteria?
Clara Lemos
Hi @Edward Rosario ,
You can navigate to the Script Includes table and open this one: 'IncidentUtils'
If you verify the code in there you can add below the comment : /***************Custom changes****************/
The function canCloseIncident, in this function you should add the condition to show the "close" option.
You probably are looking for something like below 🙂
var IncidentUtils = Class.create();
IncidentUtils.prototype = Object.extendsObject(IncidentUtilsSNC, {
    initialize: function() {
        IncidentUtilsSNC.prototype.initialize.call(this);
    canCloseIncident: function(current) {
        if (current.incident_state != IncidentState.RESOLVED)
            return false;
        if (gs.hasRole("admin"))
            return true;
        return false;
    type: 'IncidentUtils'
If that helps please mark my answer as correct / helpful!
And if further help is needed please let me know
Cheers
Ankur Bawiskar
@Edward Rosario
@Clara Lemos has already pointed out the function which controls the visibility
I would like to highlight the widget which shows the button and how it's invoking the script include
Name of widget: Incident Standard Ticket Actions
