How to integrate Serviceow and AD for creartion of user using catalog form
Prathamesh Cha1
Hi Team,
I want to create data of user in AD using catalog form in servicenow.
can anyone tell me from where I should shart.
want do I required?
2 ACCEPTED SOLUTIONS
Omkar Mone
You can configure a Flow Designer for that request which will call the Create User action of your AD Spoke in IntegrationHub.
Below ServiceNow KB can help you get started.
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0852207
Hope this helps.
Hi @Prathamesh Cha1 ,
I think it is only available in store , so you might have to download it in a customer's development/test instances.
If my answer helped in any way, please mark it as Correct & 👍Helpful
Mahathi
MahathiVeeR
As Omkar has suggested, Flow designer and integration hub is the recommended way to do it.
There is an AD Spoke available in Integration hub.
Some quick references:
https://www.servicenow.com/community/developer-forum/create-user-from-servicenow-to-active-directory...
You can also use Workflow editor with Orchestration packs to incorporate user creation using Catalogs.
There are orchestration packs for Create user and enable mailbox which are OOB.
Mahathi
