Flow Designer , In subflow with script for Email message body , some value is not populating flow
jaiho_rai
When tried to access the subflow variable and tried to dotwalk value is not appearing
Case table contain  --- field Partner that is referencing to customer_account , Incident case -- referncing to incident table .
var CaseNumber = fd_data.subflow_inputs.casenumber.number; ----> value showing
var PartnerName = fd_data.subflow_inputs.casenumber.partner; it's not showing
var Incident  ---> fd_data.subflow_inputs.casenumber.incident_case -->it's not showing
Hi @jaiho_rai ,
Please check in the case in ask has partner and incident case values.
yes they do have value and everything in place , only they are referencing type field .
So is your issue then that you are using these values in a different place where there is a field mismatch?
Please share details.
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
you are right @Community Alums , some values was not there on the case...thanks for catching up the issue.
Awesome !! Glad to see i could help you @jaiho_rai
