Best solution for delivery process in FSM
Gianluca7
I need to define a technical solution for the process of delivering assets from the warehouse to the point of sale (location), including order preparation, DDT generation, tracking and handling. The aim is to minimise customisation and make the most of what is available out-of-the-box via the FSM module. Possible solutions include using a transfer order or extending the task table by creating a custom table. Which solution is preferable? What are the pros and cons? Are there any better solutions?
15 REPLIES 15
Hi @Gianluca7
ok i got you , yes you can use and associate the TOs with distribution channels  as well .
For more details please Refer the below Link
https://www.servicenow.com/docs/r/washingtondc/it-asset-management/procurement/t_CreatingTransferOrd...
https://www.servicenow.com/docs/r/washingtondc/it-asset-management/procurement/consume-local-asset-s...
https://www.servicenow.com/docs/r/washingtondc/it-asset-management/hardware-asset-management/associa...
Thank You
