Process Flow (Formatter) does not translate anymore
02-15-2022 06:14 AM
Hi friends
Suddenly, the formatter with the states in WO (Work Order) and WOT (Work Order Task) don't translate itself anymore:
Here's an example with French. Note that the translation works in the state field of the form.
The translation was also checked by me on the sys_translated-list. Everything looks fine.
What could this cause? Any idea?
Daniel
- 4,635 Views
01-26-2023 11:10 PM
No, still the same issue. We accepted it and didn't investigate further. Thanks for asking. 😃
Daniel
01-27-2023 12:06 AM
Ahh, that's unfortunate. Especially since it's working in my instance using the settings shared in this thread. For what it's worth it, the only thing that I would suggest that hasn't been mentioned here is to check the application scope in which the translated record was created. It seems that there might have been some issues with that, looking at the below post. It also provides a possible solution. It might be worthy to look into it.
I hope it helps.
Have a nice day!
