Adding Resolution Note in Portal
komal zatale1
I have a requirement to add the Resolution Note in the ESC portal, in Activity Stream, there is a widget name-"Ticket Conversation"
Added the Screenshot, to exactly where I needed it.
Can anyone help me with the requirements, as I am new to this.
2 ACCEPTED SOLUTIONS
Mark Manders
I would go for the easy way (and also the way it is meant to work): copy the resolution notes to the comments, so those can be seen on the portal. You can even add 'Resolution notes' + resolution_notes, so it's clear in the comments where it's coming from. OOB there is even the functionality on cases for that: 'add resolution notes to comments'.
For incidents it's not there, but you can make it automation (add every resolution note to the comments) or work through the same functionality: have the agent tick a box to decide it it should or shouldn't be there.
Mark
I did not get this. Can i have the clear path?
I have to do it from OOB way (no scripting allowed for us)
Context :Resolution notes should appear on portal as additional comments.
Sandeep Rajput
