03-04-2026 01:33 AM
Hi Team,
I have two fields in Incident Form 1. Sub Category (Which is Choice List ) and Service Offering field ( which is a Reference field to Service_offering table where 44 choices are present).
My Requirement is when a Particular Sub category is selected for Ex: Hardware then only Service Offerings related to Hardware should be visible in the Lookup of Service Offering (Ex: 4 Service Offering are related to Hardware) and remaining 40 Choices in table shouldn't be Visible. And in the same way Sub category is selected for Ex: Software then only Service Offerings related to Software should only be visible in the Lookup of Service Offering and other choices should be hidden.
How can i Achieve this requirement. Request you to provide your Suggestions.
Thank You!
03-04-2026 05:20 AM
I had a similar use case a few days back, and here’s the approach we used. It’s not very difficult, but I’ll highlight the steps:
Steps Used:
Create BS and SO
Establish relationships between them.
Create Category and Sub-Category
Use the System Choice Table for this.
Dependency Between BS and SO
To manage this, the best approach is to use a User ID Decision Table.
Reason: It’s easy to maintain, especially if you plan to add more categories or sub-categories in the future.
Decision Table Setup
Decision Table 1: Map SO → Category.
Decision Table 2: Map BS → SO → Category → Sub-Category Group.
Form Setup
Once the decision tables are in place, you can create a lookup table-like behavior on the form.
Client Script
Create a client script to call the decision table(s) on the form.
This ensures the selections dynamically follow the mapping logic.
03-04-2026 09:38 AM
Hi @chaithanya gund ,
Just to pitch - then why? There is a best practice OOTB in relation to business service and service offering according to CSDM. Why have a dependency towards hardware? I would recommend you to challange the requirement instead of doing this, as I could foresee a rather huge overhead of maintaining this.
