Linking problem and/or incident records to risk registry statems
04-03-2026 10:34 AM
When incidents are created and then we create a problem, we see the Accept Risk option on problems. However, we don't see a way to actually link the problem or incidents to an IRM risk statement or risk registry item so we can adequately track problems by risk statements. Anyone else linking their problems/incidents to risk registry items in IRM, and if so, how is this achieved?
04-04-2026 06:02 AM
There is no direct relationship between Problem/Incident and IRM Risk Registry items. The "Accept Risk" button on Problems is part of the risk assessment workflow but doesn't create a linked record in the IRM Risk Registry (sn_risk_risk).
Recommended approach to achieve this linkage:
1. Use a Related List with a custom M2M table Create a many-to-many (M2M) relationship table between problem (or task) and sn_risk_risk (Risk table in IRM). This gives you a Related List on both the Problem/Incident form and the Risk Registry item, letting users explicitly link them. This is the cleanest, most maintainable approach.
2. Add a Reference field (simpler but limited) Add a reference field on the Problem/Incident form pointing to sn_risk_risk. Quick to implement but only supports a one-to-one link per record.
3. Automate with a Business Rule or Flow When "Accept Risk" is clicked on a Problem, trigger a Business Rule or Flow Designer flow that automatically creates or links a corresponding Risk Registry item in IRM, pre-populating fields like risk description, category, and source record.
4. Leverage the CMDB/CI relationship If your risks in IRM are already tied to CIs/services, you can use the shared CI as the connecting thread — query risks by the same CI affected in the incident/problem. This gives indirect but meaningful traceability.
Best practice combination: Use option 1 (M2M table) for explicit manual linking plus option 3 (automation) to auto-suggest or auto-create risk links when problems are promoted from incidents. Add a reporting dashboard using Performance Analytics to track problems grouped by linked risk statements.
