Query on Fix Notes Copied from Problem to Incident
pgvaishnav
Hi Team,
I am trying to understand from where the Problem Fix Notes are being copied into the Incident Work Notes.
Scenario:
When an Incident is in On Hold – Awaiting Problem state, and the linked Problem record gets resolved, the Fix Notes from the Problem are automatically copied into the Work Notes of the Incident, and the Incident is then resolved.
I have been trying to identify where this behavior is being triggered from (Business Rule, Flow, Workflow, Script Include, etc.), but so far I haven’t been able to locate it.
Could you please help me identify where this update is happening?
Thanks in advance.
Pushpaka
Kilo Expert
Hi @pgvaishnav ,
There is a Business rule on problem table "Raise an event when State changes " which triggers an event  " problem.state_change" , this event triggers a script action " Update Incident when Problem closes", which updates the fields on incident which you were mentioning above.
Thank you
Pushpaka
15 REPLIES 15
@pgvaishnav
seems you missed my below response which answers your original question -> how and from where fix notes are copied to work notes
You need to check any after update BR, Flow or Workflow is copying the other fields from PRB to INC
Ankur Bawiskar
@pgvaishnav
Here is your answer
-> When user clicks OOTB UI Action "Communicate Fix", it triggers an event "communicate.fix" and value from fix_notes is passed to that event
A script action is linked with this event and gets triggered when event is processed
UI Action
Script Action: It grabs the value of fix_notes and then sets that in work_notes of INC
pushpaka111
Hi @pgvaishnav ,
Thank you
Pushpaka
pushpaka111
Hi @pgvaishnav ,
There is a Business rule on problem table "Raise an event when State changes " which triggers an event  " problem.state_change " , this event triggers a script action " Update Incident when Problem closes", which updates the fields on incident which you were mentioning above.
Thank you
Pushpaka
Pushpaka
Kilo Expert
Hi @pgvaishnav ,
Thank you
Pushpaka
