addDays is not working
smondal
Kilo Explorer
Hi everyone,
I have written the below piece of code.
bit it is not working.
Can anyone please help me on that.
var time=current.u_meeting_date;
  var gdt = new GlideDateTime(time);
  gs.addInfoMessage(gdt);//this is coming
  var timeupdated=gdt.addDays(7);
  gs.addInfoMessage(timeupdated);//org.mozilla.javascript.Undefined@4964c7 error
Many thanks in Advance.
9 REPLIES 9
adiddigi
Basically what you are missing is, addDays doesn't return any value. What addDays does is, it will modify the current object, here gdt by the duration.
So your example will work if you don't use timeupdated, meaning :
  gdt.addDays(7);
Hi Abhiram,
You are absolutely right.
below code is creating 10 more record that is expected,but what i want more like, u_meeting_date should be increased by 7 days.
fist increment is by 7 days ,next should be 14 days so on....
var loop_max = 10;//assuming integer type.
var i=0;
for (i; i != loop_max; i+=1) {
createRecord();
function createRecord() {
  //this function creates a record on the health check table
  var gr= new GlideRecord('u_cab_meeting');
  gr.initialize();
  var time=current.u_meeting_date.getGlideObject();
    gdt.addDays(7);
  gr.u_meeting_date=gdt;
  gr.u_name=current.u_name;
  gr.u_conference_information=current.u_conference_information;
  //etc...
  gr.insert();
Many Thanks in Advance
var i=0;
createRecord(i+1);
function createRecord(inc) {
  gr.initialize();
  gdt.addDays(7*inc);
  //etc...
  gr.insert();
should work for you.
Thanks Abhiram.
If it's working, please mark an answer correct.
