connection test failed for solarwinds
Venkatesh43
Hi all,
I am integrating solarwinds with serviceNow event management using OOB connector. In the connector instance I have given proper IP address and active mid server but when tested the connector it is showing following error
Could anyone help me why this error is showing.
Venkatesh
Hi Venkatesh,
To resolve this what you can do is :
1). Did you check your mid server is UP ?, you are using right credentials of mid server ?, please check that
2). Which version of servicenow you are using.
I am not sure exactly what might be the issue, but you can find the similar thread here.
You can raise HI ticket for it, they can help you.
ServiceNow KB: Outbound Web Service Calls Fail With "Could not generate DH keypair" (KB0563593)
Thank you
Hi Sampangi
How did the issue mentioned by you initially get resolved?
Make sure the user that Solarwinds is using has the role x_sow_intapp.integration_user
