Discover ExtremeNetworks Wireless controller/AP?
DaveHertel
Hi - Has anyone built Discovery pattern (or even probe/sensor...) to discover Extreme Networks Access Points?   ExtremeNetworks uses a controller and is SNMP enabled.  I'm presuming (hoping) it may be similar to Aruba AP discovery (another product without an OOB pattern...)    I've previously used John Frandsen's Aruba update set here and may model Extreme* after that...but I don't know if it'll be similar or not.   If anyone has already built the ExtremeNetworks discovery components, please share.
I'm facing starting from scratch and appreciate any helpful hints from others.    Thanks, Dave
Souvik Dutta
Hi @DaveHertel  , How did you discover Aruba APs?
There was no OOB solution for Aruba APs/controllers.   But I successfully used John Frandsen's Aruba update set here   Further, on another project I had to build a solution for Extreme networks AP/controllers.  For that, I patterned the solution based Aruba pattern which worked pretty well.
Hope this helps?
 Hope this helps??
