Discovering Aruba Switches and stack switches
rajesh44853
Hello
Can some assist here, we are able to discovery  Aruba Switch Model  JL661A and few other properly but issue is that we are not able to discovery the stack inside those and even the Serial number's are also not getting populated.
the OID's are already there in the OID table
We have series like 7x 9x 5x
15 REPLIES 15
@rajesh44853 , the Pattern name is strange. OOTB it should be "Network Switch". I see "Network Switch - Multi..." in your screen shot. What's that pattern?
The XMl is quite big to handle to output hence getting divide into multiple
Can you increase the MID Server property mid.discovery.max_pattern_payload_size (add a zero behind)?
The rest seems OK. I would recommend to ask ServiceNow Support for help.
Michael272
Did this resolve the issue?
Morgan2
We had this same issue discovering serial number information, and per ServiceNow, they don't currently support discovery of Aruba devices OOB. However, serial number info can be discovered by adding an extension to the network - switch pattern and duplicate steps 5.5, 5.6, 5.7, and 7 in the discovery section of the pattern. Use OID 1.3.6.1.4.1.47196.4.1.1.3.11.6.1.1.8. That solved it for me. Thanks!
