GoDaddy - Certificate Management pattern
mhashemi
I need to discover certificates held at GoDaddy. While I work on getting the required API key, I went looking for a documentation describing how to use the pattern. As far as I can tell, simply adding a cert management credential is not enough, so I will have to add a discovery job. I thought the "Pattern" type might work, but I do not see how to specify the pattern I want to run.
What am I missing here? Is it easier than I am making it?
9 REPLIES 9
Hello Chris - Thanks for the insight! But *I* still have issues.  Things I have tried in the Serverless Execution Pattern....  I keep thinking it is something small, this is supposed to be straight forward....
* ca_api_url: trailing "/" with and without
* Limit:  tried 175, tried 20
* start_offset:  tried 1 and 0 and blank (which I thought is supposed to be zero)
* include_cert_status: Even tried just: Installed
End up with the same error:
Information: Certificate List is Empty - Please check Credentials and Configurations (ca_api_url, ca_api_version, include_cert_status) , Pattern name: GoDaddy - Certificate Management, To Check Pattern Log
Check that your API creds are for the Prod GoDaddy API, not OTE.
Chris33
Double check your discovery settings and validate that the credential alias has a valid credential associated to it.  I would also validate connectivity to the goDaddy host url.  also in the pattern log there may be additional clues ...  I fed the log into CoPilot to search for errors but you could also search it manually.  I hope that helps.  Also, I would consider submitting a HI ticket if you haven't already to rule out any config problems.
For documentation for this thread....
Thanks for the suggestions @Chris33.  I actually had a meeting with our internal GoDaddy Admin and he was not able to create new API keys (or check the existing one) so he is putting in a ticket with GoDaddy Support to see why not.
WHEN I get all my issues worked out, I will summarize.  I have not found really good overview, or a simple setup and I have something not standard.
Thanks.
Chris McBride
Updating this thread because it's what helped me the most to get this to work.
Critical items:
  • Associate your Credential with the sn_disco_certmgmt.GoDaddy Credential Alias
    • (thats what was preconfigured with CIM 4.2 that I have loaded)
  • Edit the Serverless Execution Pattern
    • limit = 20
      • (may be able to adjust after testing)
    • credentialsAlias = sn_disco_certmgmt.Godaddy
    • include_cert_status = Installed
Note that just setting the Credential Alias for the Discovery Schedule to sn_disco_certmgmt.GoDaddy is not good enough.
