How do I prevent Discovery from using SSH for Firewalls?
Doug5
I need to prevent Discovery from trying to login to Firewalls using SSH - because it creates annoying errors in the logs on the Firewalls.
I tried using a Behavior in a new Discovery Schedule just for Firewalls - which worked - but then I need to edit all the existing Discovery Schedules (and there are hundreds) to exclude the IP-Addresses of the Firewalls.  I can't use a Global Exclusion because then my new Discovery Schedule does not work.
Any thoughts?
AJ_TechTrek
Hi @Doug5 ,
You can ask network Administrator team to disable the Port 22 for Network or Firewall Devices on Network Firewall , in this case you not required to change anything at your end.
Please appreciate the efforts of community contributors by marking appropriate response as Mark my Answer Helpful or Accept Solution this may help other community users to follow correct solution in future.
Thank You
AJ - TechTrek with AJ
LinkedIn:- https://www.linkedin.com/in/ajay-kumar-66a91385/
YouTube:- https://www.youtube.com/@learnitomwithaj
ServiceNow Community MVP 2025
