How to call a System Property for Approval Group from Flow Designer?
HarikrishH
I have created a Flow Designer, and in this flow, I have added an action called Ask for Approval. In the approval action, I need to add an approval group. Currently, the approval group is configured manually, but I want to dynamically pull the approval group from a system property.
How can I reference and use a system property in Flow Designer?
Kieran Anson
You could add a look up record step prior to your Ask for Approval step to fetch the property value. This wouldn't leverage the property being cached.
Decision Builder is a better solution for storing approval groups than system properties.
However, if you want to continue on your current solution, check out @Lisa Holenstein's blog on scripted approval syntax: Scripted Approvals in Flow Designer with Flow Variables
Shivalika
Hello @HarikrishH
Please use Look Up record before this step and fetch the value of property where you have stored the approval group.
Now in the ask for approval step leverage this value obtained in previous step.
Kindly mark my answer as helpful and accept solution if it helped you in anyway,
Shivalika
My LinkedIn - https://www.linkedin.com/in/shivalika-gupta-540346194
My youtube - https://youtube.com/playlist?list=PLsHuNzTdkE5Cn4PyS7HdV0Vg8JsfdgQlA&si=0WynLcOwNeEISQCY
Hi @Shivalika ,
I tried the same, but I am unable to add or drag any values from the data pills for approval (highlighted in the image below).
Hi @HarikrishH ,
Add one more lookup record action. this time to lookup the group record. and use that action's data pill to select the group on ask for approval
Chaitanya
