If Serial Number is empty and name is same then why duplicates are getting created
Riya25
Hello Experts,
Recently we have a issue in which  duplicate CI's are getting created having the Serial Number Empty but Name is same.
As per the identification when Serial Number is empty it should have checked for the Name Identifier then why duplicates are being created instead of updating the same record?
Also,after discovering the duplicates Class is different than the class of existing CI and IP address is same also in the  Created By field name of user is occurring.
Please help!!
Riya
Hi Riya,
Can you please help which field we should consider other than serial number ,name to make a new Identifier rule especially for server table.
👉  You can use IP address attribute to create record uniquely or you can make asset tag as well if server is physical.
And also to delete the duplicates we should run the background script on individual table or base table (cmdb_ci)
👉 I suggest you to delete by individual class and check if it working fine or not it won't take much time.
whether deleting will automatically delete the their respective Relationships or not ?
👉 Yes,it will delete relationship as well.
Ajim.
26 REPLIES 26
you creating CIs using discovery right?
Riya25
Hello Ajim,
Actually i haven't created any identifiers we are using ootb identifiers only.
And we are creating CI's through Discovery and Integrations.
Riya
should I assist you to create identifier?
if yes then share attribute/field name so that I analyse them and suggest you for which field we can create identifier
Riya25
Hello Ajim, Yes we can create new identifiers but at present our problem is why name identifier is not working . According to the order of serial number is empty then it should pass to next identifier. Regards, Riya
can you share screenshot if that are not confidential just share how you created identifier entries
