IRE not being executed while using importSet using onBefore transform script
gaurav72
I am using onBefore transform script to implement IRE using below code to identify and ignore duplicate CI.
(function runTransformScript(source, map, log, target ) {
	log.info("Status Log ImpSet");
	var cmdbUtilIRE = new global.CMDBTransformUtil();
	cmdbUtilIRE.setDataSource('ImportSet');
    cmdbUtilIRE.identifyAndReconcileEnhanced(source, map, log);
    ignore = true;
    if (cmdbUtilIRE.hasError()) {
        var errorMessage = cmdbUtilIRE.getError();
		log.info('Error: ' + errorMessage);
        log.error(errorMessage);
        log.info('IE Output Payload: ' + cmdbUtilIRE.getOutputPayload());
        log.info('Imported CI: ' + cmdbUtilIRE.getOutputRecordSysId());
})(source, map, log, target);
When I run the transform I do not see any logs from CMDBTransformUtil , below is the import set logs
What would be the possible cause can someone please put some light into this to resolve it.?
Only thing I can think of now is to check that someone hasn't changed the accessible from for the Script include in your instance, it should be 'all application scopes':-
Happy to have helped even a small bit, please mark my post as useful if it has genuinely helped you.
Richard
I am assuming you are in a scoped app?
Any reason why you are using identifyAndReconcileEnhanced instead of identifyAndReconcile?
I don't currently see any issues with how you are instantiating the SI, I am wondering if you put log lines in directly after
log.info("SI instantiated");
log.info("Datasource set");
log.info("identifyAndReconcile complete");
		ignore = true;
If that would get you any closer to where the exception is being thrown...
Richard
Thanks for your prompt response Richard. It is very helpful, I appreciate it.
I tried placing logs it is throwing exception where I am instantiating the SI. I do not see the log ("SI Instantiated") , I see the log statement I placed before that line.
Where shall I focus to debug this issue to take this ahead , suggestions would be helpful .
You are correct I am in scoped application .
Richard
Thanks much Richard !! After allowing to access from all application scope it worked as expected..
Thanks for your suggestion !!
