Need help for Script include
soumyadaggula
Hi Team  ,
am using below catalogue client script to re-direct a catalogue item to Order guide , but I want to write a script include for this , so that it can be used for other order guides also . can you please guide me on how to use this script for Script include .
function onLoad() {
var tstr= top.window.location;
tstr=tstr.toString();
var sstr = "id=sc_cat_item&sys_id";
var ct = -2;
   ct = tstr.indexOf(sstr);
if (ct != -1) {
top.window.location = "esc?id=sc_cat_item_guide&table=sc_cat_item&sys_id=21470fe11b9601108be4eb53604bcb3a";
Ashish37
Mega Guru
Hi @soumyadaggula ,
You can do this by creating client callable script include and adding this code to it. you have to use GlideAjax to call that script from you client script. I  tried this and it did worked, you have to pass tstr as a parameter to script include.
Script include:
var Ashish_Catalog_opening = Class.create();
Ashish_Catalog_opening.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    openNewCatalog: function() {
        var tstr = this.getParameter("sysparm_tstr");
        tstr = tstr.toString();
        var ct = -2;
        if (ct != -1) {
            return "esc?id=sc_cat_item_guide&table=sc_cat_item&sys_id=0317ba9d47120510f53d37d2846d43bb";
    type: 'Ashish_Catalog_opening'
Client script:
function onLoad() {
    var ga = new GlideAjax("Ashish_Catalog_opening");
    var tstr = top.window.location;
    ga.addParam('sysparm_name', 'openNewCatalog');
    ga.addParam('sysparm_tstr', "tstr");
    ga.getXML(callback);
    function callback(response) {
        alert(answer);
        top.window.location = answer;
Ashish37
Mega Guru
Hi @soumyadaggula ,
Script include:
        var ct = -2;
        if (ct != -1) {
Client script:
function onLoad() {
        alert(answer);
@Ashish37
Hi Ashish ,
thank you a lot for helping me with the script include , but can I remove the sys ID in the script , and get the sys id for the catalogue item which user is trying to open , and re-direct it to order guide page , with this I can use the same script include for multiple order guides .
@soumyadaggula  Glad I was able to help. yes you can use your sys_id, if its not going to change for sure then you can hard code it in script include like i did OR if you like you can create a system property and call gs.getProperty() to use it.
Please accept solution or mark answer if my solution was able to resolve your problem. Thanks!
