Using MultiSource CMDB functionality
‎12-02-2020 01:00 PM
How to use this feature?
When I look at the CI record using the "Multisource Data Preview" link on the CI record I was expecting to see three columns. The attribute, the value and the discovery source. I only see two - the attribute and the value.
How is this any different than the audit history?
Why is it not showing where the value came from? Is there something else I need to enable other than the plugin and the system property?
UPDATE: Nevermind. Figured it out.
- 6,852 Views
‎04-08-2025 08:21 PM
May I know the fix?
‎05-11-2021 11:17 AM
I am having the same issue. I have enabled the plugin, I added the system property, and I have Reconciliation Rules defined. We are using the ScienceLogic Sync application for our discovery. When I go to the Multisource Data Preview, I only see the 'Attribute' and the 'CMDB Value' columns, no source column. I turned on the logging, and there are no entries in the sys log for the source=cmdb_multisource, and no entries in the CMDB MultiSource Data table. But the data is being updated, and the source is ScienceLogic-Sync. I have confirmed that the ScienceLogic Sync application does use the IRE.
‎10-14-2022 09:48 AM
Data will be stored in cmdb_multisource_data for all the CIs only when the required plugin(com.snc.itom.discovery.license) is enabled and required system property(glide.identification_engine.multisource_enabled is set to true) to collect multisource data has been enabled.
You can quickly test this by calling IRE API from scripts - Background with a valid discovery source, IRE should create/update a CI and also insert/update the source specific data in cmdb_multisource_data.
Please follow this documentation on how to call IRE API from background scripts to test IRE and multisource features
‎10-14-2022 10:43 AM
Thank you Kiran. I am not sure what we did to resolve the issue, but we did get it working. I am no longer on that contract and do not have access to that system. But thank you for your response.
