A notification is not triggering whenever a user self-assigns a ticket, but will trigger when.......
09-26-2025 03:23 AM
Good afternoon.!
A notification is not triggering whenever a user self-assigns a ticket to himself but will trigger when assigned to someone else.
What might be the issue?
For INC, it works, but for SCTASK, it does not work., although the same conditions are defined in both the notifications.
Please help.
@Ankur Bawiskar @Dr Atul - LNG @Viraj Hudlikar
09-26-2025 04:57 AM
Hi Sir
I tried, send to event creator, it is not working.
09-26-2025 05:03 AM
"Technically, it will not trigger. The reason could be consistency in the 'Assigned To' field. If there's no change — for example, if the value remains the same — the system might check that both the caller and the 'Assigned To' fields are unchanged, and therefore, doesn't trigger the logic. There might be some internal logic I'm not fully aware of, but this could be one possible reason.
09-26-2025 11:20 AM
Hello @AbdurRahmanSnow
As suggested by Ankur & Atul Send to the event creator is needed so an email will be triggered if that user is assigning a ticket to himself.
Also, following up with your reply, you tried the same, but it's not working. Now, is this happening for a particular user or all users? If particular users then see in their user profile that they have disabled notifications.
I tried to check with OOTB notification over PDI, and it worked fine, but for one user it didn't, and the reason was the notification was disabled in the user profile.
If my response has helped you, hit the helpful button, and if your concern is solved, do mark my response as correct.
Thanks & Regards
Viraj Hudlikar.
