Flow desiginer is not triggering after adding in catalog item form flow field
3 weeks ago - last edited 3 weeks ago
Request Management
Service Catalog
3 weeks ago
Hello @AzizM
Navigate to All > Maintain Items and enter the name of your catalog item.
Scroll down to Process Engine tab and select the desired Flow.
Hit Save/Update.
3 weeks ago
Hi @AzizM,
It's difficult to advise without being able see your flow however a couple of things to check would be
- who the flow is set to 'run as'? (System User or User who initiates session)
- has the flow been activated?
- has the flow been linked to the specific catalog item?
If you're able to share a screenshot of your flow, that would help with troubleshooting.
3 weeks ago
Hi @AzizM
I think you need to provide some additional context before we can help with your question. Please provide some screenshots etc. to get the help needed.
3 weeks ago
Hi @AzizM,
You are most likely missing the link between the flow and the catalog item — the trigger alone does not do that.
A Service Catalog trigger says when a flow may run, but the flow only runs for a catalog item when it is also selected on that item: All > Maintain Items > your catalog item > Process Engine tab > Flow. If that field is empty, no Flow Context is ever created for the RITM — which matches exactly what you are seeing. Testing the flow directly from Flow Designer works because the test runs the flow standalone and bypasses the catalog item link, so a successful test does not prove the wiring.
Check these, in order:
1. Maintain Items > your item > Process Engine tab — is your flow selected there?
2. Is the flow Active? A saved but inactive flow never triggers.
3. Does the trigger match the RITM that is created? The Service Catalog trigger is on the Requested Item [sc_req_item] table — check its conditions actually match the item being ordered, and that the flow and the catalog item are in the same application scope.
4. Then check Flow Designer > Executions for the RITM. If there is no execution at all, the flow never started (points 1-3). If there is an execution with an error, the problem is inside the flow, not the trigger.
The first check is the one that catches most people — the trigger and the Process Engine link are two separate things, and both have to be in place.
If this helped, please mark it as Helpful — and if it solved your issue, I'd be grateful if you accepted it as the solution.
