ATF If i want to schedule Test suite do i need to open client test runner and my system should be
kranthi2
ATF If i want to schedule Test suite do i need to open client test runner and my system should be open
I have test suite which will have 20 ATF tests and each will take 5 minutes and if i will schedule the ATF test suite and i want that should be run only one time that is tomorrow morning 10AM IST time,
If i schedule the same do i need to keep open my Client Test Runner should be open and do i want to keep my system should be open
Please help me out the clarification on it.
Hi @kranthi2
There is no other way,
You create a schedule test with your date and time and on the system the schedule client test runner needs to be open at that time.
If my response proves useful, please indicate its helpfulness by selecting "Accept as Solution" and " Helpful." This action benefits both the community and me.
Shaqeel
Shaqeel
Hi @kranthi2
Yes, scheduled Client test runner should be opened at that period of time.
Shaqeel
Shaqeel
Hi @Shaqeel
Thanks for the response, any alternative for this, because my client is not going to happy with that. because If i want to run the ATF, even though i have scheduled why should i need to open the Client Test Runner and that too while running the ATF It is not possible to open the some other tabs and perform some other activity
We need to stick into that Client Test runner.
Can you help me out here.
Hi @kranthi2
Shaqeel
