ATF Test Generator and Cloud Runner
OMT
Hi everyone,
does anybody knows why im not able to use ATF Test Generator and Cloud Runner. We have yokohama on our instance. We installed necessary plugins but still not able to run ATFs in cloud or to auto-generate them (screenshot with the plugins installed)
When i want to run the test in the cloud the message(screenshot) appears.
Br, T
11 REPLIES 11
Hi @OMT
It looks like the app is not installed or you don’t have the required role. It's best to log a HI Support case to get this checked."
Hi! As you can see in the screenshot, it's installed! I found out that after changing the view to 'Classic App Manager', I could see one more 'ATF Test Generator and Cloud Runner' app. After installing this, the Test Generator appeared on our platform. Without changing the view, it would not have been possible to find this app. Now I'm facing a second problem: when I select Cloud Admin, I get this message:ATF_TG:mutual_auth_config_pending_short
Hi, yes, as i said
Then  log a now Support case buddy.
