Auto number enable check box not available
NaveenKumarSN
can any one help in unhide auto number check box in incident table similarly when i create new user user there is no password field.
Please guide me to how to unhide
Barath P
@NaveenKumarSN ,
I’m glad to help! If you have any further questions, feel free to ask me in the community. I’m always here to assist you!
"If you found my answer helpful, please give it a like and mark it as the accepted solution. It helps others find the solution more easily and supports the community!"
Thanks & Regards,
Barath.P
14 REPLIES 14
I found Password field is hide using client script
NaveenKumarSN
autonumber scratch pad is true is this related auto number
Barath P
@NaveenKumarSN ,
Thanks & Regards,
Barath.P
Please help in unhiding auto number check box field on incident table form
I believe the autonumber scratch pad business rule is out-of-the-box (OOTB). Please open the autonumber scratch pad business rule and review the script carefully for any changes. If you don’t find any errors, check your update set to see if any modifications were made by you. Additionally, verify the update version of the scratch pad business rule to ensure it hasn’t been altered by someone else. If you still can’t find the issue, and if your update set allows it, you can back it out and start developing again from scratch.
