04-05-2017 09:00 AM
Hello Experts,
I have created auto numbering for existing software model table. The issue is we have few old records for which we need numbering as well but it works only for newly created records. Is there a way to generate numbering for existing records as well. Thank you in advance.
Thanks & Regards,
Jag.
Enterprise Asset Management
04-05-2017 11:49 AM
Sorry change line 6 to gr.u_number so...
var gr = new GlideRecord("cmdb_software_product_model");
gr.orderBy('sys_created_on');
while (gr.next()) {
var nm = new NumberManager('cmdb_software_product_model');
gr.u_number = nm.getNextObjNumberPadded();
gr.autoSysFields(false); // Do not update sys_updated_on, sys_updated_by, and sys_mod_count
gr.setWorkflow(false); // Do not run any other business rules
gr.update();
04-05-2017 09:43 AM
What is your column name for number field? and also your table name?
Can you please give a screen print of your form with a valid number or its dictionary
Please Hit like, Helpful or Correct depending on the impact of the response
04-05-2017 09:47 AM
04-05-2017 09:53 AM
Oh, I missed the update(), Please try now
var gr = new GlideRecord('cmdb_software_product_model');
var prefix = "SW";
var counter = "0000000";
while(gr.next()){
counter += 1;
gr.u_number = prefix+counter;
gr.update();
04-05-2017 09:59 AM
Hello Alikutty,
No luck. The number is still showing empty.
Jag.
04-05-2017 10:14 AM
I think it is because of number conversion from string and backforth, How many records do you have in total can you give me a count of it?
