Auto populate field from a reference field on a catalog item variable
riskay123
Mega Guru
I have a variable that contains a reference field that references the sys_user table.
I have added another two fields for Email and Department and I would like to have them auto populate with the related information for the selected user in the Requested for field.
How can I do this please?
Demo25
@riskay123
If it is not solved yet,,
There is no need of client Script, there is an option Auto-Populate by using this you can simply auto populate the fields  from the reference  table.
Thanks.......
Harish Bainsla
Hi please write script include for that i will share you a video link which help you to get your answer with proper explained
https://youtu.be/vKQTkKpc_co?si=rrLd8KiydvKaq9Ga
