Calculating the duration between specific project milestones in a standard report
abbasshaik4
Tera Sage
Hi Everyone,
Below is the requirement:
Requesting ability to report on Turn Around Time between Milestones on a Project. The ideal design would be to run by Project and calculate duration between any and all Milestones that exist.
For example, if a Project had milestones for Start, Plan, Build, Test, Train, and Go-Live, the report would return the duration between each Planned End Date for the respective Project Tasks. Note: The capability in the Demand module to report on turnaround times for HCL phases on PRO Status may provide direction, but not sure.
can you please assist on this , how to proceed further?
Thanks & Regards,
Abbas Shaik
Hello @Ankur Bawiskar,
Iam new to this requirement, can you please mention the detailed steps that would be helpful for me.
Abbas
Dr Atul - LNG
Hi @abbasshaik4
Standard reporting this is not possible, until you create metrics. You can use Pa with breakdown feature to get this.
