Call client callable script include from Business Rule /Background Script
mehtaaaksha
Hello Experts,
I want to use the client callable script include from business rule /Background script. Please help.
Sample Client callable script Include script
getCallerLang: function(){
    var caller_id = this.getParameter('sysparm_caller_id');
Please help to fetch the output through background script.
Note : function does not have any parameter in Client callable script Include script.
@Ankur Bawiskar
Ankur Bawiskar
yes that's possible
Same function can be called from ajax or server side like this
getCallerLang: function(caller){
	var caller_id = JSUtil.nil(caller) ? this.getParameter('sysparm_caller_id') : caller;
regards
@Abc 26
Hope you are doing good.
If my response helped please close the thread by marking appropriate response as correct so that it benefits future readers.
Muhammad Khan
Hi @Abc 26
Client Callable Script Include
var Test = Class.create();
Test.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	bothClientServer: function(prbSysID){
		var prb_sys_id = (prbSysID == undefined) ? this.getParameter('sysparm_prbSysID') : prbSysID;
		var prb = new GlideRecord('problem');
                prb.get(prb_sys_id);
		return prb.getValue('number');
    type: 'Test'
Client Script
	var ga = new GlideAjax('Test');
	ga.addParam('sysparm_name', 'bothClientServer');
	ga.addParam('sysparm_prbSysID', g_form.getValue('problem_id'));
	ga.getXML(result);
	function result(response){
		var answer = response.responseXML.documentElement.getAttribute('answer');
		alert(answer);
Server-Side/Background Script
var obj = new Test();
gs.print(obj.bothClientServer('<sys_id_of_problem_record>'));
Hopefully, this will help you understand.
