Catalog Client Script not setting the reference variable using URL parameter (value keeps reverting)
SwethanaB
Hi team,
I’m working on a Catalog Client Script (onLoad) where I need to populate a reference variable (configuration_item) based on a URL parameter ci=1.
OnLoad script:
function onLoad() {
    var ci = g_form.getParameter('ci');
    g_form.clearValue('configuration_item');
    if (ci === '1') {
        g_form.setValue('configuration_item', 'sys_id');
The variable still loads the previously used value, even after clearValue().
@SwethanaB
Hope you are doing good.
yashkamde
Hello @SwethanaB ,
try this script :
function onLoad() {
   var ci= getParameterValue('ci');
   if(ci == '1'){
      g_form.setValue('configuration_item','sys_id');
 function getParameterValue(name) {
        var url = top.location.href;
        var value = new URLSearchParams(url).get(name);
        if (value) {
            return value;
Also ensure catalog client script > ui type is set to -> ALL
