Catalog Client Script
DreDay3000
Hello, I have a catalog client script that should display a message when a check box is unchecked after being checked.
When the box is unchecked, the error message should show
 This is the script I have so far:
    if (newValue == 'false') {
        g_form.showFieldMsg(has_call_activation_number_for_this_tree_been_added, 'CANNOT CONTINUE! All items in required information section MUST be met before continuing. Refer to Instructions for more information.', 'info');
 Any help is greatly appreciated
pavani_paluri
Hi @DreDay3000 ,
There are no quotes for variable/field you used in the script. Please use below updated script:
if (newValue === 'false') {
'has_call_activation_number_for_this_tree_been_added',
'error'
If your goal is to block submission until the checkbox is true, you might also want to use an onSubmit client script instead of just onChange. That way, you can prevent the form from being submitted until the condition is met.
Mark it helpful if this helps you to understand. Accept solution if this give you the answer you're looking for
Kind Regards,
Pavani P
Shaik Dimple
Hi @DreDay3000 ,
Looks like the issue is with the field name in showFieldMsg. You missed quotes around it, so it won’t work.
It should be like this:
g_form.showFieldMsg('has_call_activation_number_for_this_tree_been_added', 'CANNOT CONTINUE! All items in required information section MUST be met before continuing. Refer to Instructions for more information.', 'info');
Field name should always be in quotes.
Dimple Shaik
Tanushree Maiti
Try with this
    }    if (newValue == false && oldValue == true) {
        g_form.showFieldMsg('has_call_activation_number_for_this_tree_been_added', 'CANNOT CONTINUE! All items in required information section MUST be met before continuing. Refer to Instructions for more information.'', 'info');
