09-21-2026 02:43 AM
Hi Community,
I have a requirement where a specific Catalog Item should be visible only to:
- Users with the itil role, or
- Users who have any role that starts with x_
Normally, I would implement this using User Criteria, but in our instance the system property glide.sc.use_user_criteria is disabled due to other business requirements, so User Criteria is not an option.
There are over 200 roles that begin with x_
@Ankur Bawiskar @Dr Atul - LNG @Allen Andreas @Hardit Singh
09-21-2026 03:49 AM
then you can use onLoad catalog client script + GlideAjax
the script include would validate if logged in user has itil role or has any role starts with x_
if not then it shows an alert to user and directly takes user to portal homepage
09-21-2026 08:38 AM - edited 09-22-2026 12:28 PM
Hello @YerragondaA3099
I believe only for such scenarios, ServiceNow has out-of-the-box "Entitlement script" field available for "Catalog items" (you can use configure form layout to show it in the catalog item / maintain item /sc_cat_item form) or use the list view: https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0685499
With entitlement script, you can make the catalog item available for or not available for to logged in user(s). As per your scenario, if logged in user has role which starts with "x_" and/or "itil", then use below code in the Entitlement script of your catalog item, impersonate that user and validate it:
var roles = gs.getUser().getRoles().toString();
var hasItilRole = /(^|,)itil(,|$)/.test(roles);
var hasXRole = /(^|,)x_[^,]*/.test(roles);
answer = hasItilRole || hasXRole;
NOTE: (^|,) means Beginning of string or comma because user may have multiple roles and (,|$) means exact text
Validation Results:
Before:
After:
09-21-2026 12:52 PM
I like this option! 😀
09-21-2026 10:52 PM
Hi @Vishal Jaswal ,
Thanks for the response
I initially tested by keeping the Entitlement Script toggle disabled, and then enabled the Entitlement Script toggle with the following logic. However, even for a user who does not have the itil role and does not have any role starting with x_, the catalog item is still visible.
Could you please check and advise if there is any additional configuration required for the Entitlement Script to be enforced?
09-22-2026 12:29 PM
@YerragondaA3099
Only visible to those who have 'itil' role or role(s) starting with 'x_'
