Catlog Item Creation on Daily for every 5 mins using Scheduled Job
Rajesh Bandila
I have created the one catalog item and that catalog item need to submit the system automatically on daily for every 5 mins. I have written the below Scheduled job script and it's working as expected when i click on Execute Now UI action button and it's not ordering system automatically. Please let me know how to automate the every 5 mins?
Please refer the below Script for your reference.
var cartId = GlideGuid.generate(null);
var cart = new Cart(cartId);
var catalogItemSysId = '7198552237b1300054b6a3549dbe5dea'; // Replace with the actual sys_id of the "AZA" catalog item
var item = cart.addItem(catalogItemSysId, 1);
var rc = cart.placeOrder();
gs.info('Created AZA catalog item.')
Thanks in Advance!!
Hi @Rajesh Bandila
You can replace the below script and you can try it and it is working in my pdi
var currentDateTime = new GlideDateTime();
var currentDayOfWeek = currentDateTime.getDayOfWeek();
currentDateTime.setTimeZone('CET');
var gdt = new GlideDateTime();
var dateTimeString = gdt.toString();
var timesection = dateTimeString.split(' '); // Split the date and time sections
if (timesection.length === 2) {
    var timeSection = timesection[1]; //getting the time part
    var timeParts = timeSection.split(':');
    if (timeParts.length === 3) {
        var hour = timeParts[0];
        var minute = timeParts[1];
        var second = timeParts[2];
// Check if it's Monday at 7:00 AM CET
if (currentDayOfWeek == 2 && hour == 7 && minute == 0) {
    gs.info('Created AZA catalog item.');
    gs.info('Not the right time to create AZA catalog item. Current time: ' + currentDateTime);
Please mark helpful and mark as solution if everything works.
Thanks and Regards
Sai venkatesh
Hi @Rajesh Bandila
you can use periodically
thanks and regards
Sai venkatesh
