change GlideAjax method from GetXML() to GetXMLWait()
sureshp89882164
Scenario is: A 'Pop-Up' message will appear on-screen when any end-user attempts to re-assign (more than one time) already assigned incident to the Technical Service Desk (TSD).
Which one is the best one either using with GetXML() OR GetXMLWait()
Currently using with GlideAjax method GetXML(), what changes i have to do if I change from GetXML() to GetXMLWait() on below code:
 var ga = new GlideAjax('assignmentCountincident');
    ga.addParam('sysparm_name', 'getIncidentCount');
    ga.addParam('sysparm_inc_sysid', g_form.getUniqueValue());
    ga.getXML(responseParse);
function responseParse(response){
    if ((answer>=1) && (newValue == 'f1bb47cadb2e83008449f6e9bf96190f')){
alert('Incidents are not to be reassigned back to TSD for resolution, customer call back and/or further team re-assignment. );
script include: assignmentCountincident
Ankur Bawiskar
@sureshp89882164
remember getXMLWait() won't work on portal as it's not allowed as it's synchronous.
You can continue using getXML() which works in native + portal and is asynchronous.
getXMLWait() is synchronous and makes sense to use when next action is dependent and should wait till response comes from Script Include.
miftikhar20
Hi @sureshp89882164,
You should keep using getXML(). It’s asynchronous, works in both native UI and Service Portal, and keeps the interface responsive.
getXMLWait() is synchronous, freezes the UI, and isn’t supported in Service Portal, so it’s not recommended.
Your current script with the responseParse callback is the correct and safe approach for this scenario.
Thanks & Regards,
Muhammad Iftikhar
If my response helped, please mark it as the accepted solution so others can benefit as well.
