Change Management Workflow is Skipping CAB Approval
‎10-02-2017 03:48 AM
I want the change request to go for a CAB approval after the Requester's manager approves it, however, I'm having three issues.
1. It's skipping the CAB approval
2. The state should change to Implementation, but it is changing to Waiting for Approval
3. It is creating the implementation task without CAB
Change Management
‎10-02-2017 07:51 AM
How can I use the CAB field on the form in my Workflow?
On Mon, Oct 2, 2017 at 9:37 AM, pavank <community-no-reply@servicenow.com>
‎10-02-2017 07:54 AM
‎10-02-2017 08:22 AM
You need to use Approval — User workflow activity instead of Approval — Group activity.
‎10-02-2017 10:25 AM
‎10-02-2017 10:40 AM
Can you right click on the field and let me know if it is state field or stage field on the form?
