Change Management
01-05-2026 02:45 AM
When I open the change record in native UI and if conflict status = "conflict". it shows :
Change Management
01-05-2026 06:54 PM
Hope you are doing good.
01-06-2026 11:23 PM
Thanks for your support.
Now I am able to show the Message on SOW Workspace but Schedulling Assitant is not clickable.
01-07-2026 12:07 AM
I believe I answered your original question.
Please mark my response as correct and close the thread.
The discussion can continue on answered thread as well.
01-05-2026 10:22 AM
That conflict message showing in native UI but not SOW is a common gap with those old client scripts. Check out the linked thread Ankur mentioned—it has a solid workspace client script example to trigger the notification on load. Should get you the same behavior without much hassle.
