Check box true when based on conditions met
lokesh211
Hi
I want to check box true which is read only based on conditions like
Planned Implementation Start Date' is greater than 'Actual Implementation Start Date' & 'Planned Implementation End Date' is less than the 'Actual Implementation End Date '.
I tried Business rule for this function but it's not working.
This is the code that i used:
var plannedStartDate = current.getValue("start_date");
var actualStartDate = current.getValue("start_date");
var plannedEndDate = current.getValue("end_date");
var actualEndDate = current.getValue("end_date");
if (plannedStartDate > actualStartDate && plannedEndDate < actualEndDate) {
current.setValue("field_to_set", true);
else {
current.setValue("field_to_set", false);
})(current, previous);
Please help me in correct this code or provide any suggestions instead of BR.
Thanks in advance for providing me solution.
Hi @lokesh211 ,
Can u put current.update() after setting the value and check please
