Column width
‎06-07-2011 08:03 AM
Not sure if this is the right place to raise this question...
How do you adjust the width of a column when looking at all tickets, I can modify the column by using 'Personalize List Columns' and add/remove etc
Would like to be able to drag the width of the column, like in excel etc
Is this possible or is it a limitation of the Toolset ?
- 25,666 Views
‎11-29-2016 03:29 AM
Hi Chuck is there a solution yet ?
‎11-29-2016 05:46 AM
None that I'm aware of at this time.
I invite you to open an enhancement request! Our product managers DO listen.
Enhancement requests: Tell us how you would improve the ServiceNow product
‎08-28-2013 01:44 AM
I have also experienced the need of List columns to be expandable, There have been requirement around it multiple times.
‎01-21-2015 03:57 AM
We could also benefit from this feature being added...
‎11-11-2015 07:13 AM
I am amazed. More than 4 years later, and we still crave this very basic feature.
If ServiceNow could at the very least provide us with some per-table option to configure the default width of columns in list view, that would be absolutely great, and I would be more happy than ever in my life.
As an example... I have a table, which shows multiple information per month, so every month is a single column. Each column shows maximally a 2-digit number, but they have the width of ~40 characters. Due to that, the table with a few additional columns takes the space of more than 2 full widths of a FullHD monitor (so more than 2160 pixels wide), which is highly uncomfortable.
