Column width
‎06-07-2011 08:03 AM
Not sure if this is the right place to raise this question...
How do you adjust the width of a column when looking at all tickets, I can modify the column by using 'Personalize List Columns' and add/remove etc
Would like to be able to drag the width of the column, like in excel etc
Is this possible or is it a limitation of the Toolset ?
- 25,666 Views
‎05-10-2018 10:23 AM
Actually, can someone clearly explain how we can use field styles and the width CSS parameter in a useful and successful way ?
While it seems to make some differences, it also seems that there are many subtleties associated to how one can define that width field style and how it really impacts the list views one can see.
For example, we did look at the browser developper tool, and could not figure out where this width field style is injected into the web page, and why it sometmes impact the layout, and sometimes not (depending maybe on the width of the screen, and/or the number of fields displayed in the list).
I also add my voice to everyone else in this question to state that this level of control in list views is long overdue.
So any and all feedback from SN on this subject will be welcomed, either explaining the usage and impact of width CSS parameter, or when this feature will finally be available within SN.
‎07-25-2018 08:47 PM
Hi guys,
I have figured out a workaround that may be of assistance in this. You set the width of the field on the actual form by right clicking on it 😉
Right click on Field. Go to Configure Styles. Leave 'Value' empty so it applies to both lists and forms. You can set it to anything you want, it's a percentage of screen size. 10 is good
Style: width: 10px !important; // change width as required
‎07-09-2019 10:36 AM
Thank you!!!
‎08-17-2018 01:55 PM
Chuck is doing it right!
Here is a KB on this.
https://hi.service-now.com/kb_view.do?sysparm_article=KB0695430
Cheers,
Anthony
‎08-17-2018 03:31 PM
Can you give me a big thumbs up? HEYOOOOOOO 😄
